It is currently Tue Aug 12, 2025 9:23 pm
 Post subject: Hard water deposits
PostPosted: Wed Oct 14, 2015 11:11 am
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
Zip/Postal Code: 64081
I have a metal trough for soaking sides/purfs/bindings prior to bending .There are a lot of nasty white crystalline looking deposits all over the bottom . What is the best way to dissolve and clean them. I had a similiar problem in st louis on a humidifier when large white clacium looking deposits would crud up everything Thanks gaah
 Post subject: Re: Hard water deposits
PostPosted: Wed Oct 14, 2015 11:16 am
First name: Danny
Last Name: Vincent
Never used it but there's a product called CLR that makes the claim.
PostPosted: Wed Oct 14, 2015 11:33 am
Read the label. Some of these products can;not be used in certain metals.
Ordinarily these deposits are like limestone and acid will loosen or dissolve it.. A weak acid is vinegar. I soak humidifier wicks in vinegar, but I do that in a plastic dish.
You might keep these deposit to a minimum in a tray if you pour out all of the excess water and rinse it down after each use.
PostPosted: Wed Oct 14, 2015 4:37 pm
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
That/s the problem .I forget an leave the water in. Will try t vinegar . It/s too tricky to dumpout water in the bsmt from the metal trough. Thanks
PostPosted: Wed Oct 14, 2015 6:17 pm
I use distilled water for anything like that - for exactly that reason.
PostPosted: Wed Oct 14, 2015 11:06 pm
City: winnipeg
State: manitoba
Country: canada
How large is the trough?
Use water from your dehumidifier in the trough it is virtually distilled water. I would prefer a plastic trough if that is workable.
I use dehumidifier water in my spray bottle for wetting sides for bending and for washing out glue brushes.
Good luck
Bob :ugeek:
PostPosted: Thu Oct 15, 2015 9:30 am
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
T hanks gud idea use distilled water .I no longer have a humidifier. I spoke to a sawyer and he says to let the wood cycle through heat , dryness/humidity . etc. But cannot verify his theory . He has a kiln an bandsaw mill
Users browsing this forum: Bing [Bot] and 26 guests
